Motor sat for ten years. Just did carbs and fuel pump and replaced oil lines.
Fired off and runs great. But no oil being pulled into pump. Disconnected linkage on oil pump and advanced it. It sucked oil pretty good.
Tried it again a week later, will not pull oil no matter what I do.
Is there a procedure for checking the pump? Just pull it off and check gear?
I would like to try to fix it correctly before I Just eliminate the pump.
Thanks Tom
Thanks Tom
