77glastronssvs188
- Aug 27, 2011
- 2
just got a new "old" glastron 188 ssv with mercury 115 outboard. Took it out engine ran strong. As the day went on the throttle lever had to be pushed further forward each time to engage the engine. I had to pull back with a bit of force to get the boat back into neautral. bye the end of the day the boat would not go into reverse. I
took apart the control box. It is a mercontrol. The choke lever and plate it is connnected to works smooth. The throttle forward reverse plate still has a bunch of tension going backwardv"toward" neutral and reverse but i can move it easily forward. I took the engine cover off and the cable seems to slide easy in the slot in the engine. Any thoughts is it a cable issue or do i just need to "push it back so the pin aligns and put it back together?
this is the first time i have done any of this so if you have suggestions. ill take them.
