SuperYooper
- May 8, 2011
- 26
I have two issues right now. The first is when the engine ('71 Mercury 650)idles, it seems to rev up for a bit while sitting there and then comes back down to idle without me even touching the control. I just put in a new switch box/coil pack due to the other one being junk. It fires right without even having to turn over once, but the idle has me curious.
Two: I have an aftermarket throttle control box which I am thinking is not really right. It will throttle the engine up, but will not shift it into gear. On the engine the shift cable hooks onto a "***" in a slider. I am not sure where that slider should be to be considered in gear. I am really afraid something is wrong with the shift rod and the lower unit is going to have to be yanked apart. The slider will come all the way forward (toward the boat) but the engine will not shift into gear. The cable I have is not strong enough when I try to push it into reverse. Do I just need another control box or am I up sh*t creek here?
http://cgi.ebay.com/ebaymotors/_W0Q...emZ320740373003QQsspagenameZSTRKQ3aMEWAXQ3aIT
Will the above Mercontrol box be a potential solution? Any suggestions are greatly appreciated. Thanks!
