andersonspartsplus
- Aug 22, 2011
- 4
198? Mariner 115 HP inline 6 power trim CDI ignition
Put the boat in the water, let it warm up and took off. It ran great on the trip across the lake. Throttled it down for a minute and then back to WOT and it fell on its face. I blurped the choke to see if it was lean and it died. Fired right back up, but the problem was still there.
Sparks plugs are soaking wet all the time. Motor idles and revs fine in neutral, sputters at midrange and boggs at WOT. Using a very excessive amount of fuel. No leaks around the outside of the fuel pump.
All 6 plugs have spark. Even swapped in new plugs...same same.
So my question is could a bad fuel pump be leaking to much into the crank case? Or could the carb internals be causing these symptoms?
At any RPM in and out of gear when I shut it down and pull the plugs all 6 are soaking wet with fuel.
Any idea what would cause these symptoms?
I am very familiar with all other manner of engines both 2 and 4 stroke, not a lot of experiance with outboards.
