andersonspartsplus
- Aug 22, 2011
- 4
Hope someone out there can help me out.
This is a 198? 115hp Mariner with power trim 6 cyl inline, 3 carburetors and diaphram type fuel pump
New spark plugs installed
Prop redone
lower unit gear lube changed
new impeller
Put the boat in the lake and after it warmed up, went to WOT and it was great same as always. After docking it and heading back out it is surging at midrange and at WOT it is only moving about 15 mph. The engine sounds like it is bogging at WOT. Doesnt seem to misfire, just doesnt have any power.
Runs perfect on the muffs and in neutral. In neutral it will rev with no hesitation at all. I changed the fuel tank with a new tank. Also doesnt seem to help squeezing the primer ball.
The carbs are dripping with fuel and it seems to be using an excessive amount. I noticed bubbles in the inline fuel filter near the pump. Is this normal?
Should the primer ball soften up at WOT?
Starts and idles just fine. Runs on the muffs fine. Again in neutral it revs as normal but under a load the motor wont pick up rpms like it always has before.
I have experianced a bad prop before, Motor screams boat doesnt move....thats not whats happaning here. At WOT it acts as though its only running on 4 cyl.
I keep coming back to a fuel issue because of the excessive fuel dripping from the carbs.
I checked for spark when its cold and hot...has good spark both ways.
Any ideas would be greatly appreciated.
Prop redone
new impeller
