Re: is there a trick to starting a mariner 75 (1991)
If it's a 2-stroke then the proceedure is this.
3. Turn key to on and push to activate the fuel enricher for about 2 seconds.
Craig
Mine is somewhat leaner than that and sometimes it takes 30 seconds or so with additional squirts (pushing in and holding till engine recovers) while it's sputtering and coughing in coming on line. Once I have started mine, it is good to go the rest of the day and I can start it easily in N with no throttle advance (idle) with no priming (pushing in of the key) if I don't leave it off for too long and it cools down. If it does I follow Craig's comments.
On the first start of the day, one of my problems is that I don't boat that often so it takes time to get fuel to all the right places. If I boated daily, or frequently then Craig's comment would probably apply to my engine too.
HTH,
Mark
