Removing power tilt from a mariner 115 1993
dane80
anyone know how to remove the power tilt cylinder piston rod? every thing looks simple except the pin at the top on the main piston connected to the motor, the large pin has a flat head slot and it will not come out there is a hole on the housing is that a pin I need to drift out? it does not want to budge.
any help appreciated thx- Dave
Re: Removing power tilt from a mariner 115 1993
Yes, there is a pin driven into the PTT piston end, and then into the stainless rod. The hole that the pin is driven into goes thru, so you may be able to tap it out from the inside. Be sure to spray it with penetrating oil, as it may loosen it some.
