SPLMAXSAM
- Oct 24, 2010
- 137
Went fishing today and ran into a problem. I use a dual binnacle control to operate both Mercury 700 and a Mercury 9.9 kicker motor.
My 1978 Mercury 700 was running good. I would fished a little and would move to next spot. My problem started when I tried starting the 700 with the Neutral Lock and throttle in the up position. The motor started and hi revved. I quickly moved the throttle back to the neutral position. After that the motor starts and throttles up and down BUT will not go into gear.
I removed the boat from water and noticed the PROP free spins all the time (neutral or in gear). I also noticed I still had to put the dual binnacle shifter in gear to raise the motor for trailering.
QUESTION
Is there a SHEAR pin near the propeller or should I look somewhere else?
