sea ray 711
- Aug 16, 2011
- 2
engine runs great but won't run over 4000 rpm's under load good compression. I think its electrical any ideas?
Thanks for all the replies tomorrow I will check the rectifier its not a gas problem same prop since new 1994 has good compression I had two burnt out voltage regulators which I replaced I'm certain its electrical and I'm not too good with figuring out electrical!Try disconnecting the yellow wires to the rectifier and taping the connections. Go take her out and see if the problem goes away. If so, replace the rectifier.
