JPGBU1
- Aug 8, 2010
- 30
ok. bought a merc 2+2 115 95. Engine was sitting for 3 years. Put it in the water and ran fine, just a bit of hesitation when hitting the second 2 cylinders. Then the boat sat for 1 week. I trailered it 20 miles and but back in the water and I had no power past 2K RPM. I pulled the carb's and cleaned them spit shine. I replaced some oil and fuel lines. I pulled the accelerator pump and cleaned and it seemed to be pumping fuel fine. I cleaned the fuel filter on that feed to the injectors. I pulled the two injectors on the bottom two cylinders cleaned, tested, and put back together. all coil packs are fine and it has new plugs.
STILL NO POWER PAST 2K RPM~!!! could the accel pump even though pumping fuel be bad? it is adjusted correctly. idles like a dream runs fine on lower RPM and just has nothing at the 1800 RPM mark. oh and the compression reads 120 accross the board. could it be electrical? Trigger? stator? switchbox? any help would be appreciated if you have seen this before...
