Re: mariner 60hp 3cyl
Maybe your needle is stuck shut and not letting fuel into the bowl. I would remove the carbs and in the process see if there is fuel in the bowl. When you pump your fuel line ball, fuel fills the carb bowl until the float rises to shut off the flow, that is why your ball gets hard. If the needle is stuck, fuel is not allowed to enter the bowl and would act as you describe. I had this happen 3 times this year, the Ethanol swells the rubber tip on the needle valve and it gets stuck in the seat. I have been running my motor out of fuel or close to it after every run. Once that needle is stuck, there is no way to unstick it other then removing the carb and plucking it out with needle nosed pliers. The needle just sits on the tab of the float, working the float in order to free the needle doesn't work.
