I picked up a 1986 Merc 2.2HP today for cheap. It started first pull, and compression felt and sounded great. The only problem was that there was no telltale stream. I let it idle for 10 minutes, and the head didn't get hot at all. I read that sometimes the telltale port coming from the cylinder jacket on these models can get plugged. And it was, completely. I decided to take the head off, since I figured that would give me a good look at just how much corrosion and crud was in there. I am both glad I did, and wish I didn't.
The water passage in the head was completely blocked. I should have taken a photo before I cleaned it out (photo below is after) but there was no water flowing. It might have kept cool enough when at idle, but I dont think it would have been OK at full bore. The cylinder jacket also had a lot of crud in it, which I cleaned out. I guess this is what happens when you run motors in the saltwater and dont flush them after. The major problem is that I snapped two of the head bolts. I've tried vice grips but they wont budge.
My plan is to keep hitting them with PB Blaster and some heat and see if they free up. If not I the next step will be to weld a nut on the end of each "stud" and try again with a wrench, or just cut them off flush and drill so I can use an EZ out or something similar. Final resort would be to drill out the bolt completely and then re-tap to a larger size. Hopefully I can fix this, because this appears to be a low run-time motor and I would love to get it running again.
