Re: 1981 70hp Mercury o/b no spark
ok, heres the results . I checked the stator its ok, i checked the rectifier- good. i checked all the trigger wires good. I only have cyl #1 sparking so i took each coil and attached it to the green wire terminal on the switch box, all have good spark on that terminal. So is the switch box bad , or do i need to switch around the 3 trigger wires to see if the dead cyl's follow in suit? Otherwise ill get a box for it. TIA
