Hi There, I have a 2004 Mercury 40 HP 4 stroker. After about 3-4 minutes at WOT I get an alarm followed by a rev limiter......I go to neutral and can apply SOME throttle but if I open it up again it will shut it down...The pee stream is strong...and only warm.
From what I can tell this may be a low oil pressure alarm?? The oil level is fine and it looks clean. Perhaps the wrong weight??
The engine is fitted with a 15 P prop. Just changed to it...runs about 5400 at WOT....is this an issue???
I live in Charleston, SC...the water temp is 88 and the ambient as you all may know is in the high 90's...
Any thoughts???
Any thoughts???
