hi, im new to the forum and have been reading alot of good imfo on here about some cooling problems. i have very little water out of the telltale peehole., changed the water pump impeller and the same thing. , talk to a locall shop and he said to check the sleeve at the top of the discharge pipe going into the power head. if it looked good then the power head is no good. it has worn threw on the inside. id like to get some imput on this before i decide to scrape the motor.
