Please Help!!! My motor runs fine most of the time. When it acts up, it might only happen once or twice an outing. It runs like it is only on half the cylinders. When this happens I can go wot and it won't have the power it should. I can't get on plane. Sometimes at wot cruising 60 mph it will just die, like you turned the key off....no blubbering or cutting out. I can trim down a little, hit the key and it starts right up. I can even stay on plane while this happens. I did find a bad voltage regulator. It had a hole burnt in it. I replaced it and it still does it. Any help from you guys will be greatly appreciated. Thank You.
