CardsFan84
- Apr 4, 2011
- 20
I have a 93 Mercury 2.5L 200HP carburated outboard on a 90 Ranger 391V. The motor was running fine for three months then two weeks ago while running to a spot in a bass tourny the motor started to knock. I shut it down immediately only starting it one more time to try to detect where the noise was coming from. After two weeks of having people look at it and looking at it myself here is what I have found. The compression of cylinder number four is 0psi. The other five cylinders held between 110 and 120 psi. The flywheel was turned with the plug out and I could see the piston moving (does this eliminate a broken rod?). I am trying to determine all I can before paying 350-450 bucks to have the motor torn down. Is there anything else to check and what hope do I have of spending less than $1000 on this motor?
