kjspylite
- Jul 2, 2010
- 37
1989 Mariner 75 HP 3 cylinder
serial # 0C167888
compression within 7 PSI on all 3
Motor starts great and idles fine. Both in the water and on the muffs.
My motor is bogging under load. It has no acceleartion....zero. Just barely above idle speed. Sounds like its missing. I think I'm dropping one or two cylinders. I've made a DVA adapter and checked parts according to CDI's website. Tested while on the muffs, everything seemed fine. I did a spark test and all three jumped a 7/16" gap. I have a hard time gauging how strong the spark looks because this is my first boat. I can say it was not yellow, but a whiteish blue spark. When I was on the water, I pulled the plug on each cylinder, one at a time, to see what affect it would have. Pulling #1 had no change. The motor ran exactly the same. Pulling #2 the motor ran very roughly, very noticible difference. Pulling #3, I had a hard time telling if it made a difference. Sounds like I'm looking spark on at least #1, maybe #3 also. Very confusing since my DVA tests looked good. Its possible my tests were inaccurate because I am a novice, however, I did my best to follow the CDI instructions as well as the factory manual. I've looked all through the fuel system and do not believe it to be a problem: cleaned carbs with new gaskets and properly adjusted floats, needle seats looked good, new fuel lines, new fuel pump, checked for air bubbles with clear line, tried portable tank, new fuel fittings, have tried numerous idle mixture settings with no change, pumped the primer bulb or hit enricher with no change. All this leads me to belive its a spark issue since my compression is OK. Does this sound right to you guys?
I pulled the flywheel and this is what I found:
the insulation on one of the trigger wires is cracking and the casing has some cracks in it. The flywheel looked to be rubbing the stator a little. The magnets in the flywheel look good.
Lastly, I found I have a 16 amp stator, but I do not have a regulator, just a rectifier. Stator model number was Mercury part # 398-9873A24.
I have pulled plugs immediatley after shutting down on the water and found no signs of water intrusion. Nothing was steam cleaned and no water on the plugs.
Again, my DVA tests seemed good and they all three jumped the 7/16" gap, but I am still convinced I am dropping cylinder(s) and this is an ignition problem. Can anyone make any sense of this? Thanks for your help.
serial # 0C167888
