Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Charging Problems
  • Charging Problems
    I have a 2000 Merc 50HP 4 Stroke on a 21' Pontoon boat. My problem is with the charging system. When I start the motor the charging rate is 12 -13 amps. After a while when the motor gets warmed up if I happen to hit the trim switch the charging rate goes to 0, and will not start charging again until I stop the motor and restart. I have replaced the stator, the voltage regulator and a couple of sensors and installed a new battery--still does the same thing. When the needle goes to zero on volt meter, the RPM needle is erratic and the trim will not work. Any suggestions?
