dennisryan2
- Jul 23, 2011
- 5
Went on a fishing trip and after making a 40 minute run to the fishing spot the beeping noise started. When the key was turned an interval beep started and did not stop. The engine did not need to be started for the beep to start. It only continued when the motor was started. Could this be a minor problem. I still haven't figured out why it beeps. The beep was coming where the starter is (about 4 inches away). Does anyone have a clue as to what could be causing the beep? Thanks
