Switch Box
I have a 1994 Mariner 40 hp magnum tiller steering on a 14' Jon boat. Last week motor ran fine. Last night it took about a 1/8 mile to plane off. At idle and low rpm's motor sounds and feels like it is skipping. No low end power then all of a sudden it has full power. Pulled each spark plug wire off while running and narrowed it down to #4 cyl. # 4 spark plug looks very clean. Swapped #3  coils and there was no difference. Also swapped spark plugs after the coil swap just in case #4 plug was dead and still no difference. Could it be the switch box? Or does the switch box handle 2 cylinders at a time, meaning I would have a misfire on a another cyl also. Thanks.
