My '78 1400 has a 9 amp stator...it has the two yellow wires with the red srtipe...How do you test these stators? Should i have continuity between either of the yellow wires to ground, or continuity to the frame of the stator? When i check ohms between the two yellow wires i get a reading of .3 on my digital meter...both yellow wires have continuity to ground...what is the correct readings?
