Re: mercury 850 high idle/rev
It may be both, or idle timing. It sounds like you should check link and synch. I recommend a service manual, to help set the timing and synch correctly. Remember, you can set the idle set screw, but the throttle cable still needs to push the throttle closed. Ad a bit of preload to the throttle cable adjustment to assure the throttle is pushed to the idle stop.
