Re: 89 Mercury 8hp 2 stroke oil leak from the exhaustion hole on top (newbie)
Thank you Mi duckdown and Texasmark: here is the better explaination after 1 day trying to find out:
I just bought a 1989 8hp mercury 2 stroke. It's pretty new, the owner said it max 10hrs used. When it start running, I saw a black oil coming out from the bottom. Guess it was from the gear casing, I did change the gear oil. However, when start the engine again, the new green color gear oil start to float in the water. Overnight, the oil did not leak, until I start the engine again. It has a green color so I think it came from the gear case. I call a local mechanic and he said it was the seal inside the gear casing that caused, but this board is pretty new. Can i fix this myself or it's pretty much the job of mechanic to change the seal? if any ? Do you know what is the problem? Thanks again.
