ChatWizard
- Jul 25, 2011
- 5
I have an early 80's (at least i think, has the double blue bands) 50 hp mercury thunderbolt. I have it on a 15 ft bayliner capri bowrider that I just bought this year. Was working great but last run out the only way I could put it into gear was to have the pre idle on (if shut off engine would die). We were out in the middle of the lake when this happened so really had no choice. It would of course make a clunk noise (kinda like when a car transmission does when parked on a hill) when putting into gear from neutral, by the end of the day when we started heading back i heard a pop sound a couple of times and then the engine would start to rev up to max rpm's without the boat going anywhere. This happened everytime i would start to accelerate past idle speed. The motor worked fine at idle speed with the pre-idle pushed up and got us home at about 10 kph. I think i may have damaged a bearing or gear with the hard engaging but am not a mechanic so could be wrong.
Any ideas would be greatly appreciated, before I go starting to tear things apart i might not have to.
Thanks in advance.
Here is a video of the motor if it might help http://www.youtube.com/watch?v=oK1r-4v6gqc
Thanks in advance.
