exnavyman123
- Apr 17, 2010
- 123
I went boating this weekend and wasn't running the boat long at all and a beeping alarm sounded from inside the throttle box, i think there was water coming out of the pee hole but don't remember, is this the overheat sensor? I was hoping the temperature sensor was just faulty, and needs to be changed.
2Nd problem : When i had the throttle lever at full throttle (a while before the alarm sounded) the boat would only goes less than half power , the priming bulb was not getting firm when i put it in the water i was told that problem could be vapor lock?
Thanks
Thanks
