I have a 1996 Mercury 115 hp motor. When I purchased the motor (used) it seemed to run well for me. Over the past year I have noticed only at WYT it would bog down or cut out, but if backed down slightly it would run fine. Last weekend this problem became much worse and I seem to have problems from 1/3 throttle and up. Occassionly when I went from idle to WYO, the motor would run well for about 1 second and then bog down. I pumped the bulb while at WYO which had no effect. I tried spraying carb cleaner into the carbs with no effect. Last night when I returned home I pulled the spark plugs which were new approximately 3 months ago. Plugs 1, 2, and 3 had some oil and gas residue, but no significant carbon buildup on them. Plug 4 was completely clean and had no residue whatsoever. I plan to test the compression on the four cylinders tonight. From my very limited knowledge, it seems I have a fuel supply issue, but I don't know where to start. Any suggestions?
Thanks,
mac_in_mt
Thanks,
mac_in_mt
