Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Mercury 50 -- No neutral, cranks in gear
  • Mercury 50 -- No neutral, cranks in gear
    I replaced the impeller on my mercury 50 and reattached the LU. When I crank the engine, the motor is in gear...I have no neutral. Any ideas or solutions?
    Re: Mercury 50 -- No neutral, cranks in gear
    When you pulled the LU, was it in neutral?
    • #3
      I can't say for sure but I am almost positive it was.
      • #4
        That can be an issue if it wasn't. What you may have to do is pull the LU again, and get a cloth and pair of pliers and turn the shift knob on the LU until you get it into neutral. It has 3 positions, so you just grip it tight and use the cloth to protect the splines and turn it until the prop spins freely both ways. Then you can put your shift lever on your control box in neutral, and reattach the LU. That should get you in neutral and when you start it, it should be in neutral.
        • #5
          When I shift the shift rod goes up in forward back down in neutral and further down for reverse.
          • #6
            are you talking about the shift arm on the control box?
            • #7
              I don't know...I'm not a mechanic, just handy. I think my engine is different because the trim tab and screen are not "standard" for a 50. Just saying...In the link below, this guy is working on the same 50 I have.When I started removing the LU, those two nuts on the shift rod (the first thing he disconnects) were in the middle of the opening. When I put it back together they are now in the top of the opening. I think I am starting in forward and when I shift up the rod moves up but is still in forward. And when I shift into reverse it goes down and then "pops" back up into forward.
              http://www.youtube.com/watch?v=7FKtsJzTXgM
              • #8
                My apologies, I assumed you meant an older model 50. That is my mistake. I should have immediately asked you what year model it was. My knowledge on newer motors is limited. Someone here will help you out.
                • #9
                  Thanks for your help...I will repost and see what happens
