Re: 88 mercury classic 50 45 hp engine is hard to start
I put my fast idle to about 55% when cold and use the choke, and 55% with no choke when restarting it when its warm. When my needle valves were stuck, and it has happened to me 3 times, I had to do as you say but I could never put the fast idle to off and keep it running.
If you're saying it starts on a really hight fast idle setting and you can't shut it off, you are running on 1 carb. Remove the carbs and clean them, unstick the needle valve. You'll know that is the problem if you remove the carb bowls and one of them is dry. On mine, the ethanol in the fuel is causing my needle valve rubber tips to swell and stick in the seat.
