superjuice
- Jul 8, 2011
- 9
Greetings, I am the proud new owner of a 1972 19' aquasport CC with a 1985 75hp 4cyl mercury outboard located in CT. I bought the boat knowing that the engine was in need of repair due to a loud knock that the previous owner experienced. According to him he limped in and pulled the boat last summer. He also didn't have it winterized because he figured it was a goner, which it may well be.
I just opened the motor up and a bunch of wires going to the stator are split and corroded. Mostly the yellow wires, they just crumbled away in my hand. I plan on doing a compression test tomorrow, hoping for the best.
Obviously the wires or stator need to be replaced but could a stator failure cause a knock, or would it just die. Just wondering if I should sink any money into this engine or just find a new one. The good thing is that it has a 5 year old lower unit, replaced at the local dealer. I was thinking of even finding a 84-88 90hp in better shape and swap that in using the same controls and maybe even the lower unit. Thanks for any help you guys can offer, John.
