i have weak spark 25,000 volt on a spark test gauge it should be 40,000. the motor is hard to start and idles rough, it also has no power, you put it in gear and hit it, she will stall. i have ohmd the trigger and stator according to manual, it test fine the coils ohm good on secondary. i have cleaned the carbs and check the floats. i have not checked fuel pressure yet but it seems to be getting plenty. i am at a loss, any suggestion would be greatly appreciated. i am thinking the spark advance module is causing the problems, but not real sure.
thanks for any help u can give
