Max1991trophy
- Mar 13, 2011
- 6
I was running my boat the other day and I ran over some kelp and noticed I was dragging it. I stopped turned off the motor and lifted it out of the water. The kelp was easily freed as it was not wrapped around the prop. I then headed in at full power. About 15 min after that my rpms went down and felt like I lost power. I drove the boat into the dock. Then lifted the outboard out of the water and salt water started pouring out from under the cowling. I then put the motor back in the water and started it. I then noticed that there was a black circular part on the starboard side of the engine towards the bottom that had a hole in the middle of it and that is where the water started coming in at. I had a whole weekend planned and really need help and answers. If anyone can help let me know. Thank you
