longshanks
- Jun 12, 2006
- 188
I just bought this motor used, and there was a dealer-installed charging system on it, so that it will charge a 12V battery while running. There are a couple battery leads coming out from under the flywheel. I've asked around about this but haven't got a clear answer.
Can I run this motor with those leads disconnected? I'm thinking that while the motor is running, those leads would be hot, and I'm not sure if this can be easily disconnected or disabled, maybe by removing a fuse or something? My main motor charges the battery, and I have no need to charge with the smaller 9.9....
any ideas?
any ideas?
