Last weekend i took out my boat for about 8 hours going all thru the chesapeake bay fishing for cobia. On the way in my over heat sensor would come on for about 10 seconds then cut off after doing that twice it stayed on. Now its 2 days later and i went to flush the motor at my house and before even turning the key all the way to cut on the motor the over heat alarm is going off already. Is this a faulty sensor? If so do you know how to find the sensor on the motor so i can try discounting and reconnecting to see if that will reset it?
