1968 125hp mercury
chrisken
Hello
first time on this site
I just got a boat with a 1968 125hp mercury and i got it running but no water was comin out the hole at the top so i pulled the bottom half off and to check the impeller. anyway I was looking around on the internet and noticed there is suppose to be a exhaust tube in there as well but there isn't. Is it ok to run it with out the exhaust tube from the top to the bottom? Will it burn the seals in there?
Thanks Chris
cbone
Re: 1968 125hp mercury
you talking about the pee hole? sometimes it gets clogged, insects go in it, or dirt from the engine, stick a coat hanger up it
