shadowrider
- Feb 19, 2009
- 195
I have touched on this in the past but have new infomation and felt best to start new thread. I have a 73' Merc 850 with a jet pump. I recently added a tach to verify motor performance. I have been through link and sync proceedure and everthing seems hunky dory. Motor idles around 650 rpm, therefore I assume tach is right. At wot, I am getting 4150 rpm. Unlike a prop lower unit, a jet pump is not effected by load, and can develope full rpm at a stand still ( boat on trailer in water). This is a fact stated on the manufacturers website. I called the manufacture and talked to a technichian, he verified that the pump I had was the right one and I was using the proper 7 3/16 liner/impeller. I asked about changing to a smaller impeller and he said it would only gain 200-300 rpm and would not advise it. He could not shed any light on why I am not getting more rpm. He stated that I should be getting around 5300 wot, at least. Motor has 140 psi on all 4 cyls, runs great other than the low top end rpm. I can not find a great deal of info on jet pumps on here. I am stumped, Hope you guys can help me figure this out. Shadowrider
