Last year I found where the insulation on the wires that run the tilt and trim system had deteriorated, and the T&T would not work. I fixed this problem by applying heat shrink tubing and then wrapping with electrical tape. This year the tilt and trim merely clicks and does not move. I released the screw on the starboard side of the pump so that i could move the engine up and down. The clicking when you hit the switch is intermitant. Does anyone have any suggestions?
