Re: Mercury Prop torque??
Place all related prop parts when assembling. Adjust prop nut with fingers untill very tight, try to pass split pin through upper nut cut and prop shaft hole, if mission impossible, turn nut CW some degrees untill you can pass the pin through.
Happy Boating
