Hi All,
Merc serial number #A-1416029. I think I've got this nailed down to a 1961 Merc 700 (and a half?). It's an inline 6...I can tell you that much.
I'm very new to this forum, though I've been reading for a couple of months at least. I've been in search of the procedure for dropping the lower unit/replacing impeller/seals on this outboard I've recently acquired (on the back of a 1960 Glasspar Marathon that I also plan to restore). I thought I was having luck with the Sierra Marine catalog alone, but upon calling my local boat shop (Brothers Boats in Folsom, CA) I was told that the Sierra part number I had down for my "Impeller Repair Kit" was for a later model. The catalog points to Sierra #18-3217.
I'd like to drop the lower unit and pull the impeller housing/gaskets/seals just so I can take them in to my local shop to find replacement parts but the only manual I've been able to find (per the FAQ in this forum section) is the 90-300. The closest I can find is very detailed instructions for a 1966 90hp...I'm not sure how similar my lower unit is to this one, if at least for the purpose of a cooling system service.
Any tips on finding a manual would be greatly appreciated. Also, if you can throw in a recommendation for a marine battery for this particular beast that would be great, too
I've also emailed repairmanuals4u.com and am awaiting response.
Thanks,
Aaron
Thanks,
Aaron
