Recently bought boat and having engine trouble any help would be much appreciated!
When starting the boat from cold it does start with choke and fast idle on sometimes but on a few occasions it wont start at all and will just turn over and over without a pop or bang. If it does start I can then run it on fast idle to get it up to temp and then reduce idle and will sit happily at 1000 rpm for a short time but if left in neutral will cut out.
If i then turn the engine off (change fuel tank etc) it really struggles to start and sometimes it will just drain the battery to nothing and then im in the brown stuff! I prime the bulb of course.
I have tried to think of what the problem could be I have changed and tested lots of things I will list my findings and what i have changed.
Spark plugs
Fuel pump/Diaphragm kit
Fuel filter
Checked Carbs and floats there clean
Checked spark it jumps 8mm and looks stong on each cylinder
Checked compression
Cylinder One (top) 130 psi to 140 psi
Cylinder Two 130 psi to 140 psi
Cylinder Three 100 to 110 psi
Cylinder Four 130 to 140 psi
Engine Ser No 09660421
I realise the No 3 cylinder is low compared to the others but that is still good amount of compression!?!
Any help greatly appreciated thank you for taking time to look at this thread
Spark plugs
Fuel filter
Checked compression
