Hi,
I am having trouble getting my shift cable adjusted properly so reverse engages. Forward and neutral are ok but the cable doesn't extend far enough to fully engage reverse. If I disconnect the cable and move the shift mechanism on the engine, reverse works fine. I have the barrel on the shift cable turned all the way in (making the cable reach longer) and it is about 1" short of matching up with the connection on the shift mechanism. I took the shift control apart (Quicksilver Commander 2000) but it doesn't appear you can adjust anything there to extend the cable farther. There is one stud to attach the cable to in there. Any ideas what I am missing? Is there a good tutorial on the adjustments.
Thanks!
Ron
Thanks!
Ron
