Re: 50 hp mercury outboard 500 friend put in water pump now its stuck in gear
I have the same issue with a 1978 800 (80hp). How do you change the gear on the lower unit? I also only have one gear changing shaft, not an upper and lower like the Seloc manual I have says, so no direct ability to change gears there. My prop does spin only clockwise in Forward, Neutral and Reverse (from the shift controller at the helm).
Did you get your issue resolved?
