importeater
- May 17, 2011
- 5
I think I know the problem, but haven't messed with outboards much so I need some help from those that know. I just purchased this boat and was told the water pump impeller had just been changed. I took it out on the lake and it did fine all day. There were a few forward and reverse gear changes. Then all of a sudden I noticed it will not come out of forward gear. So no nuetral or reverse. Acts as though it's locked up and I don't want to pull to hard and damage the cable.
Is it possible when they put the lower unilt back on the shifter lever was not lined up properly? I just don't know why it worked as long as it did if that is the issue. I haven't done anything yet so I wanted to get some info first. Of course it won't start since it won't go into nuetral.
