Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
197? mercury 110 9.8 hp running problems
  • 197? mercury 110 9.8 hp running problems
    recently aquired a early 1970s mercury 110 9.8 hp , after some new wireing and an imppeller, i had it running , ran great in barrel, shifted into forword and reverse fine, but in lake it doesnt seem to run well, when first started out it would sputter and die at WOT, after a while of playing it ran ok but still didnt have much "get up n go" its on a 14 ft aluminum oachita flatbottom, maybe pushed me about 7 mph
    question is were do i start in getting MORE outa this motor?? any advice would be great maybe another owner of this motor
    thanx Kenny
    "Grounds 4 Divorce"
    Re: 197? mercury 110 9.8 hp running problems
    First things first, what are the compression readings. Second, is it firing on both cylinders?
    sigpicSignature- If you have fuel and spark- Have you checked compression?
    • #3
      Yep +1
      • #4
        first pull 80 psi on each cylinder great spark on top cylinder bottom cylinder is missing/ sparked 1 outa 4 pulls, i know whe i got the motor i had to replace the brown wire to kill switch (dryrot) and the green wire to the coil on cylinder not fireing properly and it looked like the red wire to the other coil had been replaced previously,
        next step? swap wires to coils around and see if its the coil or wires from under flywheel?
        "Grounds 4 Divorce"
        • #5
          Do you know if this motor has the phase maker ignition? A SN would be a good start. If it is phase maker, they have isolation blocks down under the points that attach from the points and go to the coils. Over time these blocks either melt or crack and cause a leak to ground, absence of trigger so the coils don't fire or fire intermittantly. I suspect that's why you aren't getting the performance you want out of the motor, on one cylinder a twin is an absolute dog.
          • #6
            the front of cowling says "thunderbolt ignition" if that helps and the serial # is 3264735, acording to the mercury serial # to year model chart its a 1972 ish ,
            "Grounds 4 Divorce"
            • #7
              well through process of elimination ive determaned the coil pack for lower cylinder is bad , DARN, called local marine place 70 bucks hummm guess could be worse, maybe with it fireing on both cylineders i can get some life outa this thing
              "Grounds 4 Divorce"
              • #8
                Did you swap coils around? Some of the coils have a ground strap which comes out the back of the coil and grounds agaist the coil holder, sometimes the coil ground wire corrodes.
                • #9
                  ya i swaped wires around, took wires from coil that was fireing (#1)and put them on none firing coil (#2), no luck, then hooked wires up that go to none fireing coil (#2) to good coil (#1), had great spark, so if #2 coil didnt work with eather set of wires im guessing its bad , right?
                  "Grounds 4 Divorce"
                  • #10
                    Wires- you are talking about the wires coming from the points vs the plug wires. If so , then yes.
                    • #11
                      yes the wires coming from unde rthe flywheel,
                      well its back togeather and now firing on both cylinders, 80 psi on both cylinders guess time for round 2 of test in the lake LOL hopefully i dont get out run by a turtle thistime LOL
                      "Grounds 4 Divorce"
                      • #12
                        You should be good to go, spark on both makes a HUGE difference.
                        • #13
                          ok now for my next problem, i know this is the wrong forum but what the heck, this motor is on a 1972 0uachita 14' aluminum rivited jon boat, with just the motor and gear in it it floats rather level, once my fat butt (230) lbs gets in the back it feals like it sits way to low in the back, the only flotation is the styrofoam built into the three benches across the boat, is it posable to add flotation foam of some sort to the back of the boat to help with the weight issue? if so were do i start to look for it and what type and all?
                          "Grounds 4 Divorce"
                          • #14
                            Won't help, you need to put ballast in the front of the boat to offset your weight. All floatation foam does is keep the boat afloat if it were to sink. Some people use sandbags, a spare gas tank, I usually bring my buddy. However , you haven't run at full power , at 7mph I can't imagine your boat getting on plane. Run it again and see how you fair out.
                            • #15
                              wow what an amazing difference, thank you for all your help and guidence bktheking, my merc purrs like a kitten now and gets up on plane great, id say 10 ta 14 mph and water was a lil rough thow, now a hole new problem LMAO , man boats are a expencive hobby bout so far even with the brokein evinrude i bought first i still have less then 1000 in the hole rig 275 for 14 ft boat, 175. for evinrude 9.5, 275 for mercury and 150 in parts, guess i aint doin to bad,
                              "Grounds 4 Divorce"
