accentphoto
- May 4, 2011
- 128
I am debating on buying a '83 Grumman 5.0 and it has a 90hp Mariner on it that seems to have a few problems. The owner says it fired up last year and that he replaced a switch box but I am not sure what was really done.
A little history before getting real dirty. The motor looks good. He had the cowling off all winter so there was a small amount of rust and corrosion. I pulled the plugs and they looked great! The compression on 1-5 cylinders was 152, 154, 158, 154, 154. I couldn't easily get to the bottom cylinder but after those readings I expect is okay.
Carbs probably have old fuel in them from his last attempt to start. I tested the starter solenoid and replaced it with a new one so now the starter engages the flywheel with the ignition key. I cleaned each terminal on the starter solenoid, starter and the main harness ground wires and coated them with a dielectric grease.
I measured grounds all around the engine and it seems to be good. I pulled #1 plug, grounded it and noticed no spark. I realize I probably need to check each one and I am probably jumping the gun on guessing there is a problem elsewhere (could even be the ignition or "run" switch position. Are there any quick test points to check for positive on the motor to make sure the ignition "on" is getting signal to the switch boxes?
I realize the only positive coming in is the main positive lug to the starter solenoid and from there it goes to the 20amp fuse (new, cleaned and greased) and the but rectifier but what does the gray wire from the wiring harness do since it goes to the other connector on the rectifier?
Any suggestions? Thanks!
