I have a mercury 110 (9.8hp, 1976). I took exhaust cover/baffle and cylinder block cover off looking for blockages in the cooling system. New gaskets are on the way however question is: do these gasket go back on dry or is there some goop/sealant that should be used? Also should some lubricant (never-seize) be applied to the screw threads?
Tom B.
(LongLine)
Tom B.
(LongLine)
