Hello,
This is my first post here!
Ok so here my situation.
I have 1998 150 Mercury offshore carbureted that bogs at times, I changed the plugs, fuel filter, drained old gas replaced with new, compression is good in all cylinders. It starts right up and after it warms up a few minutes i can take off with no problem, but if I stop at a fishing spot or on the beach for 5-10 minutes and get ready to go again it wants to start with the choke and throttle up a little like its been sitting for days but I only stopped for a few minutes, once I let it run for a few minutes with the idle a little high I take off with no problem. Then I was trolling at a higher speed but not planed out for a few minutes then went to hammer on it to go and it bog out and died, restarted and took right off. The best I can think is carbs, I just bought it and its very clean so I assume it either sat a lot or was fresh water used. I can run all day long at full speed with no problems, its just if I stop for a few minutes or troll at lower rpms it bogs just as I try and get on it.
Any help would be greatly appreciated!
Mark
Mark
