Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Mercury Optimax Stalls at high RPM
  • Mercury Optimax Stalls at high RPM
    HI,
    I have a pair of 2001 mercury optimax 150hp on a 25' footer. Last time i went out one of the engines was running perfect at low rpms (uder 2000rpms) but everytime i would go over 2K rpms it will run fine for about 15 seconds and then stall and die. You can crank right back up without a problem and it will idle, but at this point you can open wide throttle and rpms won't go up past 1500. if you let it idle for 5-10 minutes, it will work again for another 15 seconds or so. Im guessig its getting flooded with gas, but i really don't know where to start looking. Any help will be appreciated. Thank you.
    Re: Mercury Optimax Stalls at high RPM
    Also, the temperature stays cold, there are no beeps or any other indications that something is wrong...
    • #3
      What serial number?
      DO YOU HAVE: GOOD COMPRESSION, PROPERLY TIMED SPARK, PROPER FUEL AIR MIXTURE?
      • #4
        From your discription it sounds like the VST tank
        is running out of gas.
        maybe filters, primer bulb, anti-siphon valve,
        Fuel line coming apart inside, bad lift pump,
        Plugged VST filter,
        Install fuel pressure gauge and watch
        for lost pressure.
        • #5
          Duplicate the secenario again and drain the VST into a graduated cylinder and record amount, then pump the primer bulb until slight pressure is felt and drain into same container. If your amounts vary you could have possible fuel restriction/lift pump problem, if they pretty much equal I would suspect the low pressure fuel pump. Are you the orignial owner? If you are, did you receive a letter about direct injector recall as per service bulletin 2001-01.
          • #6
            What temperature is it reading?
            • #7
              If you have a manual I would be checking the EFI system first.Could also be ignition/ timing related.
              "I hear and I forget. I see and I remember. I do and I understand."
              Haines Hunter V17C Half Cabin. Mercury V6 135 HP 1988.
              • #8
                No, im not the original owner. I bought it about a month ago so im not sure about the recall.
                • #9
                  It's cold, the needle is all the way at the bottom of the gauge.
                  No, im not the original owner so im not sure about the recall.
                  • #10
                    If problem persists, and you can not figure it out, may want to look into it. Take it to a dealer and they can determine whether it has been done by looking at the injectors, serial number, or Mercnet. I think they have to call tech service to get approval. Verify temp at Tstat with pyrometer.
