Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1983 +/- 50hp Thunderbolt, needing info on a Power Trim unit
  • 1983 +/- 50hp Thunderbolt, needing info on a Power Trim unit
    I have picked up a new rig, and the outboard does not have a power trim unit. The serial # is 7201552. I believe its a 1983-86 model motor, a mercury thunderbolt 3 cyl.
    After doing some research, I an not positively sure on what kind it did have or what would fit it. Would it be a 2 or 3 wire unit, single, dual or 3 ram set up???????
    This site has helped me in so many ways in the past with different motors, but just never registered. Any and all help is welcomed. Thank you in advance.
    Brian
    Re: 1983 +/- 50hp Thunderbolt, needing info on a Power Trim unit
    Brian;
    Your s/n comes up as a model:
    1050523 MERCURY 1983 50
    Parts listing:
    http://www.crowleymarine.com/mercury-outboard/275.cfm
    Gerry
    • #3
      Thank you for the reply. I did happen to take a look at these listings, but I have a question. Can I pick up a complete trim unit (used)?? If so, what infor might I need so that I can get the right part the first time.
