ShawnyBoy187
- Apr 19, 2011
- 2
Hi all, new to these forums. I got a 1987 Mercury 115 inline 6 cylinder and I got a question about it. At idle the motor has a shake to it out of the water. I would think that a little bit of shake is ok but this seems like more than average. When the boat is in the water and put into gear at idle the shake does seem to be worse. Enough to where I can feel it through the steering wheel, has even died while throwing it into and out of gear. Top end is smooth. No pinging or other sounds coming from motor while running. Compression is even across all cylinders. I am mechanically enclined but am new to outboard motors. I am wondering what to start replacing. I did bump the idle up from about 650 to 800 hoping that would solve the stalling when going into gear issue. Should i begin with new plugs? Carb rebuild? Any info about this would be awesome. Thanx alot.
